FC IDE coding error for INT1/REMAP in PIC24FJ64GB004 Family
An area to discuss 16-bit PIC specific problems and examples
bernoulli
Has thanked: 1 time
Post by bernoulli »
Error within the FC IDE coding for the INT1/REMAP with the PIC24FJ64GB004 family. The attach file illustrates the problem area. I believe the problem lies within the chip file information and not within the main FC IDE software
Basically, the FC IDE is using bits 0-4 of the RPINR0 register when it should be bits 8-12.
The FC IDE is correctly using the register bits for INT2/REMAP, which are bits 0-4 of the RPINR1 register.
INT1_Test_PIC24FJ64GB002__PLL_clock_8_MHz.fcfx
(16.18 KiB) Downloaded 412 times
Re: FC IDE coding error for INT1/REMAP in PIC24FJ64GB004 Fam
Many thanks for letting us know I have had a good go through the definition files and fixed the same problem on a number of devices.
Here is the new v7 definition file, simply copy to your "Flowcode 7/FCD/PIC16BIT" folder and restart Flowcode.
24FJ64GB004.fcdx
(36.66 KiB) Downloaded 445 times
I will post the other updated files on the v7 updates thread.
