CAL UART comms stops if the baud rate is updated
An area to discuss 32-bit PIC specific problems and examples
Zane
Flowcode v5 User
Has thanked: 93 times
Been thanked: 76 times
Post by Zane »
Hi Ben,
I am using a 32MX270F256B and when using the CAL UART, if the baud rate is updated the comms will stop. If the update baud icon is disabled the comms works fine. I have attached the test program that i have been using.
I have also installed the patches you have created that takes care of all the timing and peripheral issues too.
Zane
Flowcode1.fcfx
(10.52 KiB) Downloaded 393 times
Has thanked: 481 times
Been thanked: 699 times
Re: CAL UART comms stops if the baud rate is updated
Hi Zane,
Could you please try the attached CAL file?
Leigh
PIC32BIT_CAL_UART.c
(22.18 KiB) Downloaded 393 times
Zane
Flowcode v5 User
Post by Zane »
Hi Leigh,
I have tried this but it has not been successful.
Thanks Zane
OK. Thanks for testing. I'll stick this PIC32 issue on Ben's pile :)
Thanks for letting us know of the problem.
I have replicated it and have found a fix.
Simply copy the attached file into your "Flowcode 7/CAL/PIC32BIT" folder and the problem should be resolved.
PIC32BIT_CAL_UART.c
(22.11 KiB) Downloaded 451 times
Let us know how you get on.
Zane
Flowcode v5 User
Post by Zane »
Hi Ben,
Thanks for the update i will try it later on this week.
Zane
Zane
Flowcode v5 User
Post by Zane »
Thanks Ben, your magic worked a treat, it is functioning as expected now :D
