Hi!
It is not possible to compile my program in FC7. I am trying to reset TMR0 by help of a C macro. But get an error code1 if I do this.
In FC5 it work fine.
Or am I doing something wrong.
Br Jorgen
Timer0 not reset Pic 16f88 solved no bug!
- Has thanked: 1135 times
- Been thanked: 299 times
- PicUdfald.fcfx
- (10.08 KiB) Downloaded 290 times
Re: Timer0 not reset Pic 16f88!
Hi Jorgen,
Since FC5 &n FC6 uses a different compiler from FC7 then the syntax will be different.
Instead of = BoostC format
You must use = XC format.
Take a look at this post
As its not a bug, I have moved topic to a more appropriate section.
Instead of
tmr0 = 0x00;You must use
TMR0 = 0x00;Take a look at this post
Hi Martin!
Well well, I did not knew this. I make a test later today. You hear. Thank you Martin.
Br Jorgen
Br Jorgen
Re: Timer0 not reset Pic 16f88 solved no bug!
Hi Martin!
Now I can compile. Do you know, is it correct in Arduino Mega if I want to reset INT0 the C code is : TCCR0A = 0;
Thanks in advance.
Jorgen
Thanks in advance.
Jorgen
Hi Jorgen,
Sorry for the delay.
I have been on a short holiday from Friday to Sunday.
Glad Flowchart compiles for you now.
Thaks for keeping us updated.
I will leave that question to those that actually know.
I'm thinking of purchasing one so I can have a play,
Sorry I have not had anything to do with Arduino Mega.jgu1 wrote:s it correct in Arduino Mega if I want to reset INT0 the C code is : TCCR0A = 0;
Hi Martin!
No sorry, it is weekend... offtime
Again thank's for your help.
Br Jorgen
Br Jorgen
You mention INT0, did you mean timer 0 or external interrupt pin INT0 on pin D0?
TCCR0A is the Timer 0 control register. If you want to reset the timer 0 count register then you need to use the following code.Now I can compile. Do you know, is it correct in Arduino Mega if I want to reset INT0 the C code is : TCCR0A = 0;
TCNT0 = 0;Regards Ben Rowland - MatrixTSL
Hi Ben!
Yes timer 0, my mistake. Thanks for reply and info. By the way, test Tour bme280 program Thisted evening
Br. Jorgen
Br. Jorgen
