Hi all,
Noticed that the ADC resolution for PIC24FV32KA301 (5V, 12BIT ADC) is reading only 10bits (1023) instead of 12bits (4095). Tried the available two option for VREF ie; VDD as well as V+Ref tied to VDD but both didn't yield expected results. Maybe some thing has to be modified in the 16BIT ADC CAL file to include this class of PIC24 MCUs.
Can anyone help me with a solution to achieve the 12BIT resolution ?.
Thanks in advance.
RTJ Nair
PIC24 5V devices with 12-BIT ADC resolution [SOLVED]
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: PIC24 5V devices with 12-BIT ADC resolution
Until we make a more long term implementation of this feature, there is a workaround that you could try.
Please add a C icon to your project, at the start, with the following content:
That will enable the 12 bit mode of the ADC.
AD1CON1bits.MODE12 = 1;
- Has thanked: 5 times
- Been thanked: 2 times
Thanks LeighM.
Tried but the compiler gives an error and didn't switch to 12BITs,
TESTPIC24working.c
error: 'AD1CON1BITS' has no member named 'MODE12'
I checked the datasheet and it doesn't mention "MODE12" bits for PIC24FV32KA301.
RTJ Nair
TESTPIC24working.c
RTJ Nair
Perfect. Many thanks LeighM.
Now I could get the 12bit resolution.
Appreciate the quick solution.
RTJ Nair
RTJ Nair
