EEPROM issues
- Flowcode V4 User
- Has thanked: 29 times
- Been thanked: 30 times
EEPROM issues
Did a program a while back on V5, I now needed to updated with some EEPROM settings. I am using 18F25K22 and it already has some EEPROM variables being used successfully.
I program the Write and Read macros exactly the same as the other ones, however no matter what I do I cant get he EEPROM to work... However it compiles every time.
So, I opened the file up in F6, and now it refuses to compile saying:
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_EEPROM.c(72): EEPROM error - MX_EEADR not set
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_EEPROM.c(75): EEPROM error - MX_EEDATA not set
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_EEPROM.c(134): EEPROM error - MX_EEADR not set
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_EEPROM.c(137): EEPROM error - MX_EEDATA not set
4 errors detected
Error: preprocessing error
failure
Completed BoostC compilation, return = 1
Anyone know of a solution?
GRaham
4 errors detected
failure
GRaham
Re: EEPROM issues
Hello Graham,
I've just tested it here and it seems to be working. Maybe you could try my EEPROM CAL file to see if this fixes your compilation problem.
The file needs to be placed into your "Flowcode 6\CAL\PIC" directory.
Let me know how you get on.
- Flowcode V4 User
Re: EEPROM issues
No, just tried it, still gives the same error...
I have attached the V6 program, can you see if it will compile for you?
Graham
Graham
- V6 EEPROM issues.fcfx
- (177.18 KiB) Downloaded 312 times
Re: EEPROM issues
Hi Graham,
It's compiling fine for me. Please can you confirm your using Flowcode version 6.1.3.
I've also attached the current definition file just in case this is what is causing problems.
This file lives in the "Flowcode 6/FCD/PIC" folder.
- Flowcode V4 User
Re: EEPROM issues
I am using V 6.1.4
Here is more details on the compiler message if it helps
Launching the compiler...
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostc_18f.exe -v -t PIC%(chip:u) "V6 EEPROM issues.c"
Launching BoostC...
BoostC Optimizing C Compiler Version 7.20 (for PIC18 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2013 Pavel Baranov
Copyright(C) 2004-2013 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
V6 EEPROM issues.c
Starting preprocessor: "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\pp.exe" "V6 EEPROM issues.c" -i "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\include" -d _PICPIC -la -c2 -o "V6 EEPROM issues.pp" -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
4 errors detected
failure
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostc_18f.exe reported error code 1
FINISHED
I am using V 6.1.4
Launching BoostC...
V6 EEPROM issues.c
4 errors detected
failure
FINISHED
Re: EEPROM issues
This bit of the command line to the compiler looks wrong.
Can you click on Build -> Compiler options.
The settings for a PIC should look like this.
Compiler Location: $(appdir)compilers\pic\boostc\boostc_$(family:/12F/16F).exe
Compiler Parameters: -v -t PIC$(chip:u) "$(target).c"
Linker Location: $(appdir)compilers\pic\boostc\boostlink_picmicro.exe
Linker Parameters: -ld "$(appdir)compilers\pic\boostc\lib" libc_$(family:/12F/16F).lib rand_$(family:/12F/16F).lib float_$(family:/12F/16F).lib "$(target).obj" -t PIC$(chip:u) -d "$(outdir:~-1)" -p "$(target)" -swcs 6 2
It looks like you have a % symbol instead of the expected $ symbol.
- Flowcode V4 User
Re: EEPROM issues
Thanks for this, V6 will now compile however the code is no longer working on hardware. Are there some common things that typically go wrong from taking V5 code to V6 or will I need to fault find the whole code?
Re: EEPROM issues
Maybe check the configuration settings. v5 used PPP to define the configuration but v6 uses Flowcode itself so maybe things could have changed here?
A 1 second flasher test is useful to check the configuration and that the device is running at the correct speed.
https://www.matrixtsl.com/wikiv7/index. ... ED_flasher
- Flowcode V4 User
Re: EEPROM issues
There were a number of configuration settings incorrect. After matching them exactly the program compiled ok, but did not work.
Put a two second loop at the start of the program to check the clock settings, this works ok.
I have attached the program, maybe you can see something obvious.
- (176.61 KiB) Downloaded 360 times
Re: EEPROM issues
We added EEPROM initialisers in v6, look at the EEPROM component properties.
Maybe delete the contents of the Initial values property and this will do the job of setting EEPROM locations to 255 after programming.
Other then that nothing is springing to mind.
