compiler errors
Steve001
Has thanked: 460 times
Been thanked: 523 times
compiler errors
Post by Steve001 »
playing with johns dual data logger
http://www.flowcode.co.uk/mmforums/viewt ... =26&t=8357
when compiling I get the following what's wrong ?
Employing 18F4455 errata work-arounds:
* Corrupted fast interrupt shadow registers
* No stopping on H/W breakpoints after NOP2
0: (1347) can't find 0x6C words (0x6c withtotal) for psect "text46" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x68 words (0x68 withtotal) for psect "text57" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x66 words (0x66 withtotal) for psect "text14" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x66 words (0x66 withtotal) for psect "text15" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x58 words (0x58 withtotal) for psect "text19" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x56 words (0x56 withtotal) for psect "text55" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x56 words (0x56 withtotal) for psect "text58" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x3E words (0x3e withtotal) for psect "text43" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x3C words (0x3c withtotal) for psect "text41" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x3C words (0x3c withtotal) for psect "text53" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x3C words (0x3c withtotal) for psect "text64" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x3A words (0x3a withtotal) for psect "text59" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x38 words (0x38 withtotal) for psect "text52" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x2C words (0x2c withtotal) for psect "text1" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x2A words (0x2a withtotal) for psect "text25" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x26 words (0x26 withtotal) for psect "text40" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x26 words (0x26 withtotal) for psect "text48" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x24 words (0x24 withtotal) for psect "text11" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x24 words (0x24 withtotal) for psect "text16" in class "CODE" (largest unused contiguous range 0x22)
0: (1347) can't find 0x20 words (0x20 withtotal) for psect "text62" in class "CODE" (largest unused contiguous range 0x0)
0: (1347) can't find 0x16 words (0x16 withtotal) for psect "text21" in class "CODE" (largest unused contiguous range 0x0)
0: (1347) can't find 0xE words (0xe withtotal) for psect "text12" in class "CODE" (largest unused contiguous range 0x0)
0: (1347) can't find 0xC words (0xc withtotal) for psect "text29" in class "CODE" (largest unused contiguous range 0x0)
0: (1347) can't find 0x8 words (0x8 withtotal) for psect "text28" in class "CODE" (largest unused contiguous range 0x0)
0: (1347) can't find 0x5 words (0x5 withtotal) for psect "idataBANK0" in class "CODE" (largest unused contiguous range 0x0)
0: (1347) can't find 0x4 words (0x4 withtotal) for psect "idataCOMRAM" in class "CODE" (largest unused contiguous range 0x0)
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
FINISHED
Re: compiler errors
It just means that the target device has ran out of space.
its looking for 0x6C words free, but can only find 0x22.
Therefore an extra 0x4A (74) words are required.
If using ICD what about trying to reduce number of breakpoints?
Steve001
Re: compiler errors
Post by Steve001 »
cheers for that martin
