44 pin Pic18f4455
alanwms
- Has thanked: 4 times
- Been thanked: 17 times
44 pin Pic18f4455
How do I go about using the tqfp Surface mount device package with Flowcode V5 or V7. This device has 44 pins unlike the more common through hole 40 pin device?
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: 44 pin Pic18f4455
Just select the pic18f4455 when setting up the project. Creating your flowchart and generating code does not depend on the chip package. The displayed chip (when viewing it) will not match the package chosen however this has no impact at all on the generated code or the flowchart.
― C.S. Lewis
― C.S. Lewis
alanwms
Great stuff - That is what I hoped for. Thanks for the detail. Are you saying that (for instance) RC6 which is on Pin44 will simply be available on pin 44 instead of pin25 of the 40 pin device.
kersing
RC6 will be on pin 44 of the hardware just like listed in the data sheet. Flowcode does not change the hardware, it will show the 'wrong' chip in the user interface.
― C.S. Lewis
― C.S. Lewis
