You have created text properties in your project so unless you are specifically referencing these variable in your code then these won't do much.
You can rename the switch components to make it more obvious in the program which switch you are calling.
- SS1.jpg (60.64 KiB) Viewed 3186 times
Any component macros referencing the component will be updated.
- SS2.jpg (6.17 KiB) Viewed 3186 times
In the Shapes component tool bar you will find a Label component which allows you to add text objects to the panel.
- SS3.jpg (32.26 KiB) Viewed 3186 times
The text value is set via one of the component properties.
- SS4.jpg (61.96 KiB) Viewed 3186 times
One other question for stepping through programs, Is there a way to step through, and press one of the buttons as well?
This way I can see the result of the button press as I step through.
The easiest way is probably to change the switch type from momentary to latching.
Key mapping is one way to simulate the button press by holding down a key on the keyboard.
Another way might be to set a breakpoint in the program to pause the program when the switch is pressed, allowing you to step beyond the switch press event.
