Enabling A Register On A Pic
Sparkoids
Has thanked: 30 times
Been thanked: 19 times
Post by Sparkoids »
Does anyone know please how to actually enable registers on devices to use in Flowcode please?
I am trying to enable the Temperature Indicator Module on a PIC12(L)1571 and just don't know how to do it.
I want to be able to get the temperature into a Macro to check surface temperature of the device.
Here is the page from the data sheet - all ideas gratefully received!
Sparkoids
Re: Enabling A Register On A Pic
Post by Sparkoids »
Datasheet page here
Page from data sheet
(419.53 KiB) Downloaded 2975 times
Kenrix2
Flowcode v5 User
Has thanked: 72 times
Been thanked: 177 times
Post by Kenrix2 »
I made an experimental internal temperature macro but, it is written in V5.
http://www.flowcode.co.uk/mmforums/viewt ... ure#p57003
Here it is converted to V7 but, I have not tested it. Maybe a starting point for you though. Good luck.
ChipTemp.FCM
(3.23 KiB) Downloaded 389 times
Sparkoids
Post by Sparkoids »
Thank you very much indeed - I'll give it a shot...
johnsondav
Has thanked: 86 times
Been thanked: 186 times
Post by johnsondav »
Hi Sparkoids
If you don't have any luck with the component, I would like to give it try and make one for FC7. I have had a look at the base CAL for FC7, it appears to allow you to get access to all of the channels for the ADC block.
Let me know if you're interested.
Dave
