I updated from flowcode 5 to flowcode 7.2.1.4
In flowcode 5 i have no problems with the USB HID component, in flowcode 7 it doesn't work. Is there a bug?
The keyboard example has also the same problem: https://www.flowcode.co.uk/wikiv7/index. ... 7a31b97c2a
USB HID
kris Werbrouck
- Has thanked: 3 times
- Been thanked: 4 times
Re: USB HID
Please can you apply the component fixes from here.
viewtopic.php?f=63&t=18760
I believe there is a fix there for the USB HID component which should solve the problems you're having.
Let me know how you get on.
kris Werbrouck
Re: USB HID
After the update it is not possible to compile.
- Error USBHID.JPG (47 KiB) Viewed 7726 times
Re: USB HID
Hmm ok thanks let me investigate and I'll get back to you.
kris Werbrouck
Re: USB HID
I Use a ECIO40.
The files in the directory PIC/USB/ .... are still the same with viewtopic.php?f=63&t=18760
Re: USB HID
Should now be fixed by applying the update here.
kris Werbrouck
