Build Your Own ILI9163 gLCD SPI Component
A forum where Flowcode v7 user created components can be shared, discussed and reviewed.
johnsondav
Has thanked: 86 times
Been thanked: 186 times
Post by johnsondav »
Hi Everyone
Here is a component project to enable you to build your own gLCD display component using the SPI port. You are able to insert your own command codes and configure the LCD control logic to suit your own needs.
I have included a tutorial (Draft) to help with your component build.
Please help and improve where possible, as I hope success will lead to various display components to be produced and hopefully shared.
The base gLCD display component project:
glcd_base_spi.fcfx
(105.27 KiB) Downloaded 618 times
The tutorial to help guide the component building process:
LCD Tutorial Project.pdf
(1.46 MiB) Downloaded 689 times
All constructive comments welcome.
Dave
