UART ON PIC16F1613
Synergy6
Been thanked: 4 times
UART ON PIC16F1613
Post by Synergy6 »
Hi.
I am using a PIC16F1613. Attempting to use UART. However there is no hardware option available in the properties.
Can you fix this please.
Also can you check when doing so that the RXINT will be working.
EDIT: Also, what would the possibility of getting IOC interrupts working on PORT C?
Reason: Please use edit button in corner of message next time, instead of double posts.
johnsondav
Has thanked: 86 times
Been thanked: 186 times
Re: UART ON PIC16F1613
Post by johnsondav »
Hi Synergy6
The device I am looking at - PIC16F1613 does not have a UART as far as I can tell. Please find attached data sheet for the device specification:
PIC16F1613.pdf
(3.94 MiB) Downloaded 312 times
Check to ensure I am looking at the correct device.
Dave
Synergy6
Post by Synergy6 »
My mistake.
I just checked myself and found its the PIC16F1614 that has the UART hardware.
