Output Icon not working Properly
Docara
Has thanked: 28 times
Been thanked: 61 times
Post by Docara »
Could someone run the following for me and try and get the led's to light up in the "Port_Test" macro by writing either writing 1's to the port or using bit masking.
I can only seem to get it working by using the "single Bit" option BUT if you disable/remove the macro call things seem to work properly.
Motor Controller.fcfx
(12.9 KiB) Downloaded 184 times
Has thanked: 481 times
Been thanked: 699 times
Re: Output Icon not working Properly
In simulation, or on target?
Port masking works for me on simulation.
Docara
Post by Docara »
Hi Leigh,
Your 0xFF solved it - I've been a muppet!!! :oops: :oops: I've put a '1' in the "Variable or Value box" and thought the 1 would be written the whole port
Brain Fart day
Thanks Bud
Matt
