I just need I2C 20x4 LCD display component library
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
ganimides2017
Post by ganimides2017 »
Hi guys!,I noticed that in main FLOWCODE 6 menu ,in "output" component tab,I haven´t seen any I2C LCD 20x4 component to drop out the dashboard panel.How can I get it?.
I saw some FC example from a friend called MONIE JACOBSEN where I see a LCD 20x4 in dashboard panel but I don´t realize where has he got from.
Have a nice week for everyone!!
Ganimides2017
Re: I just need I2C 20x4 LCD display component library
Hi Ganimides2017,
Easiest way to find a component is to select Search.
Enter i2c and the LCD (I2C) will be shown:
(138.32 KiB) Downloaded 3064 times
You can then select number of rows and columns.
It as shows that I2C LCD should be found within
Outputs: General
However, like you I can't see it there either!
ganimides2017
Medelec35 you are awesome buddy!!!!.thank you so much!!!!!
