Problem with bit variables
Osta
Been thanked: 13 times
Post by Osta »
Var BT.jpg (90.07 KiB) Viewed 4045 times
Re: Problem with bit variables
Hi Osta,
Can you describe what specific problems you're having with bit variables?
Osta
Post by Osta »
Hello, Benj!
The bit is read as a byte.
Error BT.jpg (120.28 KiB) Viewed 4044 times
TX.fcfx
(9.72 KiB) Downloaded 233 times
Osta
Post by Osta »
And in iron does not work.....
Help!!!!!!!!!!!!!
Hi Osta,
That issue has been mentioned here
Osta
Post by Osta »
Hi, Martin !
I understand that this problem is being solved?
I will sort this out...
Thank you.
