no data transmission at I2C and 32MX150F128B
An area to discuss 32-bit PIC specific problems and examples
Pascal_2016
Been thanked: 4 times
Post by Pascal_2016 »
Hello, Forum
my Microcontroler is 32MX150F128B
My program should select data from a 24A256 I2C EEPROM and read in.
The high-loaded program runs without mistake in Flowcode 6 with a 33FJ128GP802 and 24F16KA102
The same program does not run on 32MX150F128B in Flowcode 7. If I exchange the processor 32MX150F128B with 33F128GP802 the Pin are compatible and use Flowcode 6 runs the circuit with the same code perfectly.
The interface RS232 runs in Flowcode 7 and the flashing frequency of 1 hertz is also correct.
Maybe someone can help me fix the problem in Flowcode 7.
Many thanks beforehand
32MX150F128B_I2C_EEPROM.fcfx
(124.46 KiB) Downloaded 495 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: no data transmission at I2C and 32MX150F128B
Post by QMESAR »
Hi.
As you do not mention the Oscillator frequency you use it is hard to judge however the PIC32 is tricky with its Clock configuration and your problem sure does indicate some error in this direction.
I took a quick look and the Peripheral clock/4 you are using is suspect for me (keep in mind this is just a general speculation)
it would help if you will inform us is with
(1) are using internal or external oscillator(if external what frequency?)
(2) What is the clock speed you intend to have
take care as both these has a direct influence on the I2C ,SPI and other peripherals
Pascal_2016
I work with the internal oscillator 8.0 MHz. The 10-MHz Peripheral clock is the only tact with uart, properly runs.
