PIC16F88 - PWM not working
johnsondav
Has thanked: 86 times
Been thanked: 186 times
Post by johnsondav »
Hi Everyone
I am having trouble with the PWM component for the PIC16F88, it will not compile. The compiler is reporting the following errors:
Title:
Description:
Device: PIC.16F.16F88
Generated by: Flowcode v7.2.1.4
Date: Monday, September 04, 2017 20:07:02
Users: 1
Registered to: johnsondav
Licence key: XXXXXX
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe --chip=16F88 "Flowcode1.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
Copyright (C) 2017 Microchip Technology Inc.
Flowcode1.c: 247: (1257) local variable "_FCR_RETVAL" is used but never given a value (warning)
0: (1347) can't find 0x8E words (0x8e withtotal) for psect "text10" in class "CODE" (largest unused contiguous range 0x66)
0: (1347) can't find 0x8E words (0x8e withtotal) for psect "text12" in class "CODE" (largest unused contiguous range 0x66)
0: (1347) can't find 0x8D words (0x8d withtotal) for psect "text24" in class "CODE" (largest unused contiguous range 0x66)
0: (1347) can't find 0x6E words (0x6e withtotal) for psect "text18" in class "CODE" (largest unused contiguous range 0x66)
0: (1347) can't find 0x68 words (0x68 withtotal) for psect "text8" in class "CODE" (largest unused contiguous range 0x66)
0: (1347) can't find 0x5F words (0x5f withtotal) for psect "text13" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x51 words (0x51 withtotal) for psect "strings" in class "STRING" (largest unused contiguous range 0x13)
0: (1347) can't find 0x41 words (0x41 withtotal) for psect "text15" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x41 words (0x41 withtotal) for psect "text20" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x3C words (0x3c withtotal) for psect "text11" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x31 words (0x31 withtotal) for psect "text27" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x2C words (0x2c withtotal) for psect "text3" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x29 words (0x29 withtotal) for psect "text1" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x27 words (0x27 withtotal) for psect "text28" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x1E words (0x1e withtotal) for psect "text30" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x1B words (0x1b withtotal) for psect "maintext" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0x17 words (0x17 withtotal) for psect "text5" in class "CODE" (largest unused contiguous range 0x13)
0: (1347) can't find 0xF words (0xf withtotal) for psect "text2" in class "CODE" (largest unused contiguous range 0x6)
0: (1347) can't find 0xE words (0xe withtotal) for psect "text26" in class "CODE" (largest unused contiguous range 0x6)
0: (1347) can't find 0xB words (0xb withtotal) for psect "text31" in class "CODE" (largest unused contiguous range 0x6)
0: (1347) can't find 0x8 words (0x8 withtotal) for psect "clrtext" in class "CODE" (largest unused contiguous range 0x6)
0: (1347) can't find 0x8 words (0x8 withtotal) for psect "text16" in class "CODE" (largest unused contiguous range 0x6)
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
I am not doing anything at all with the program, just initialising. Here is the very basic project which produces this error:
Flowcode1.fcfx
(8.33 KiB) Downloaded 251 times
I have come across error this by chance. I was reviewing a previous working project which does not now work, which is strange, as it was working previously. Any suggestions would be most welcome.
Dave
Re: PIC16F88 - PWM not working
Hi Dave,
Can you see if this post helps.
johnsondav
Hi Martin
You are a star. Thank you ever so much. It is working as before.
Your help is very much appreciated.
Kind Regards
Dave
Your welcome Dave,
Glad I can help.
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi Martin!
Yesterday I tested Dave´s program and with different deviceses and get the same result. After update of the file, it seemed to be ok, But what does the first and the last line mean???
What is this: PPPWWWmm.c: 239: (1257) local variable "_FCR_RETVAL" is used but never given a value (warning)
Thank´s in advance..
Memory Summary:
Program space used 380h ( 896) of 1000h words ( 21.9%)
Data space used 2Eh ( 46) of 170h bytes ( 12.5%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Data stack space used 0h ( 0) of 60h bytes ( 0.0%)
Configuration bits used 2h ( 2) of 2h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
You have compiled in FREE mode.
Using Omniscient Code Generation that is available in PRO mode,
you could have produced up to 60% smaller and 400% faster code.
See http://www.microchip.com/MPLABXCcompilers for more information.
C:\Program Files\Flowcode 7\tools\DoNothing\DoNothing.exe
FINISHED
Br Jorgen
johnsondav
Hi Everyone.
I am still having problems with the PWM for the PIC16F88. It is working in simulation but I am not getting anything from the actual chip. I have tried another chip replacement in a previously working project circuit, but still no output from pin B0 (tested using scope). Here is the project:
HF Controller 1 V7.0_v7.fcfx
(33.75 KiB) Downloaded 246 times
Its a test module for a High voltage HF controller.
Tested the chip using an older HEX file dated Feb 2016, which works fine:
HF Controller 1 V6.0.hex
(14.13 KiB) Downloaded 238 times
Your suggestions/help would be very much appreciated.
Dave
Has thanked: 481 times
Been thanked: 699 times
Could you just check your timer setting...
johnsondav
Hi Leigh
Thank you ever so much. I feel a fool to have missed that. Just goes to show, you see what you want to see and not what is really there.
Many Thanks for you help.
Best Regards
Dave
