PIC12F1572 ADC problem (SOLVED)
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
Hi All,
I would like to use ADC and UART modul of PIC12F1572.
The problem is that +Vref pin of ADC and Rx pin of UART are same pins and I can not setup Alternate pin function in Flowcode7.
The +Vref pin is not active.
Can I get some help?
Best Regards,
Lagoda
ADC_test_with_2.5Vref.fcfx
(10.14 KiB) Downloaded 340 times
8_pin allocation table.jpg (143.54 KiB) Viewed 6680 times
Re: PIC12F1572 ADC problem
Hi Lagoda,
To set-up alternative pins, first look at the datasheet on page 101:
(62.86 KiB) Downloaded 2947 times
See which pin you want to change the function of.
E.g TX which is what your currently using (not RX) from pin RA0 to RA4
Work out the required value = 4 as it's bit 2.
Add the following C code at the start of your flowchart:
APFCON = APFCON | 4;
If you want to change both RX and TX = bits 2 and 7 = 4 + 128 = 132
Add the following C code at the start of your flowchart(witin same block as OSCCON will be suffice):
APFCON = APFCON | 132;
etc.
Also, you don't want to sendChar as when the AD value is 32 then you are sending a space and not the number 32.
You should use SendNumber instead.
You may also want a space between numbers.
What I do is after sending a number I use
SendChar 13
and
SendChar 10
That makes each number appear on a new line
Lagoda
Post by Lagoda »
Hi Martin,
Thank you for your advices.
I modified the flowchart.
The Rx function of the UART is on the RA5 now.
But the "Vref+" pin is inactive, the ADC working with VDD reference. :(
Do you have any idea?
Best regards,
Lagoda
ADC_test_with_2.5Vref_v2.fcfx
(10.16 KiB) Downloaded 314 times
Hi Lagoda,
I think I have found the problem. Please can you try copying the attached file into your "Flowcode 7/FCD/PIC" folder.
12F1572.fcdx
(16.23 KiB) Downloaded 330 times
Restart Flowcode and load your project and check that the ADC component properties are still set to Vref+, it might have changed thanks to the FCD changes.
Hopefully this should now work for you.
You can check by looking at the generated C code around line 629.
    FC_CAL_ADC_Enable(3, 3, 1, 40);
If all has worked correctly then the 1 should now be a 2.
Let us know how you get on.
Lagoda
Post by Lagoda »
Hi Ben,
Thank you for your help.
Unfortunately, the problem remains.
If i set the reference VDD then in the line 626 is: FC_CAL_ADC_Enable(3, 3, 0, 40);
If i set the reference Vref+ then in the line 626 is: FC_CAL_ADC_Enable(3, 3, 1, 40);
Best Regards,
Lagoda
Thanks for letting us know. I accidentally changed the settings in the DAC instead of the ADC.
Here is the corrected definition file.
12F1572.fcdx
(16.39 KiB) Downloaded 381 times
Lagoda
Post by Lagoda »
And it works well !!! :D
Thank you very much!
Lagoda
