When compiling code that uses the TCP_IP_EB023_00_2 Component with a PIC24FJ128GA202, the following error message is generated by FC7 when using the Software channel.
I have installed Flowcode_7_Latest_240817.zip
Error returned from [xc16-gcc.exe]
C:\Program Files\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
FINISHED
This seems only to occur when the program has been closed, re-opened and then re-compiled. If the component channel is changed to 1 or 2 and back to software, and the MCU pins re-selected, then it compiles with no error. If the program is closed and re-opened again, the process has to be repeated before it will compile successfully again.
If the target is changed to e.g. a dsPIC30F4013 with the correct pins selected, there are no errors even if the program is closed, re-opened and re-compiled.
Kind regards.
Leo
PIC24FJ128GA202 / TCP_IP_EB023_00_2 component compile error
Re: PIC24FJ128GA202 / TCP_IP_EB023_00_2 component compile error
Hi Leo,
Thanks for letting us know, I will investigate the problem for you.
I can't seem to replicate this, are you running the latest release (7.2.1) and have you applied the latest fixes from here.
viewtopic.php?f=63&t=18760
leoo
- Flowcode V4 User
- Has thanked: 41 times
- Been thanked: 9 times
Hi Ben,
Thanks fore the reply.
I am running 7.2.1.4 and have applied the latest fix.
I can replicate this reliably on both the PCs I use, but if you are not able to do so then the problem is obviously at my end. I'll poke about some more to try to resolve things.
Kind regards.
Leo
Kind regards.
Leo
Hi Leo,
Please can you attach your Flowcode project file, the .C file and .msg.txt compiler messages file. This should allow us to see the problem your facing and hopefully how to overcome it.
leoo
- Flowcode V4 User
Hi Ben,
Attached are the files as requested.
This is a very simple test program to confirm that I wasn't seeing ghosts. It does reliably reproduce the problem I've encountered (on my system, anyway).
Kind regards.
Leo
Kind regards.
Leo
- Compiler test.msg.txt
- (3.36 KiB) Downloaded 238 times
- Compiler test.fcfx
- (8.2 KiB) Downloaded 240 times
- Compiler test.c
- (60.89 KiB) Downloaded 259 times
