4x1 LCD I2C
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
4x1 LCD I2C
Post by Jan Lichtenbelt »
I wanted a very small LCD. I found a 4x1 LCD with uses I2C http://www.hexpertsystems.com/LCD/. It uses the Philips PCF8576C driver.
But the first test met flowcode 7 does show the expected results, see picture.
Can someone helps me?
- Can that be due to the fact that the Flowcode minimum setting for this LCD is 1x5 instead of 1x4?
- Or does it means that I cannot use the standard LCD-I2C macros and that I have to program it with I2C commands myself?
With kin regards
Jan Lichtenbelt
LCD_I2C_V1.fcfx
(8.91 KiB) Downloaded 241 times
Jan Lichtenbelt
Re: 4x1 LCD I2C
In the mean while I found this is not a standard LCD protocol. So I stop the use of this LCD
Jan
Re: 4x1 LCD I2C
Hi Jan,
Looks like a nice little display but maybe limited to 7-seg style numeric output. Might not be too much work to make a component if you feel it would be worthwhile.
Jan Lichtenbelt
Re: 4x1 LCD I2C
Hi Ben,
Thanks for your offer. But I will first try an other LCD.
Jan
Jan Lichtenbelt
Re: 4x1 LCD I2C
Is the I2C slave address (bit0-bit6) or (bit1-bit7) in case of the LCD macro's?
Kind regards
Jan
Jan Lichtenbelt
Re: 4x1 LCD I2C
OK, the slave address in Flowcode is 7 bits from 0 to 127 (without the R/W).
I use the LCD from Midas Components MCCOG2105B. The slave address is 0x3E, but I do not see any action on the LCD.
Does someone has any suggestion to get this LCD working?
With kind regards
Jan Lichtenbelt
LCD_I2C_V1.fcfx
(9.03 KiB) Downloaded 257 times
LCD MCCOG21605B6W-SPTLYI.pdf
datasheet LCD
(1.27 MiB) Downloaded 256 times
