FLOAT variable not working?
Float variable is not working properly. the calculation say answer of 65000/1020= 63.7254 but variable show only 63.0000
- Flowcode1.fcf
- (5.5 KiB) Downloaded 399 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: FLOAT variable not working?
That's because TOTAL and ADC are integers, not floats, hence TOTAL/ADC is still an integer, which gets converted to a float value.
You need to make TOTAL and ADC float variables.
- Has thanked: 3 times
Try this instead and you should get the right result.
65000.0/1020.0
Adding the decimal point forces the values to be floats and hence use the floating point maths library. Otherwise you will be using the integer maths library for speed and efficiency.
65000.0/1020.0
