custom timer1 not work
- Francisco Cabrera
- Has thanked: 23 times
- Been thanked: 7 times
Hi friends, the option custom timer1 something is badly because it does not work, they can help me, thank you.
- general.fcfx
- (8.02 KiB) Downloaded 319 times
Re: custom timer1 not work
In your interrupt handler you currently have this.
this should instead be like this.
if (pir1 y (1 << TMR1IF)) Code: Select all
if (pir1 & (1 << TMR1IF)) Regards Ben Rowland - MatrixTSL
- Francisco Cabrera
Thank you bemg for answering, I have modified the mistake, and the interruption does not work....
Do you see well everything else? .... if I fit interruption tmr1 without being custom, in the same program it works perfectly simulating in flowcode
Custom interrupts will not simulate as they could be an interrupt for anything, they will only work on the hardware. Have you tested on hardware?
- Francisco Cabrera
no benj,
Only I have simulated it in flowcode, Then this it is the problem .... thank you very much for your help
