PIC 16F720 Interrupt - Error Message
skammann
Been thanked: 3 times
Post by skammann »
Hallo,
for my application i want to use interrupt , pls. find the file here
Interrupt001.fcfx
(10.38 KiB) Downloaded 253 times
The compiler is interrupting with error message ,
Interrupt001.msg.txt
(1.5 KiB) Downloaded 201 times
There's no error when using UART RXINT0
Does anyone has got an idea ?
Best regards
Interrupt001.c
(32.58 KiB) Downloaded 227 times
Re: PIC 16F720 Interrupt - Error Message
Hello Stefan,
Thanks for letting us know of the issue.
The attached files should solve the problem for you. SImply copy to your "Flowcode 7/FCD/PIC" folder, restart Flowcode and the program should then compile correctly for you.
16F720.fcdx
(14.17 KiB) Downloaded 224 times
16LF720.fcdx
(14.17 KiB) Downloaded 231 times
Let us know how you get on.
skammann
Post by skammann »
Dear Ben,
Thank you very much for your quick response.
copied the file into my directory , restarted flowcode and it's working.
The next milestone in my project is completed.
Best regards
