FC7 - Global Options and Print missing or hidden
viki2000
Has thanked: 30 times
Been thanked: 77 times
Post by viki2000 »
I checked next pages:
https://www.flowcode.co.uk/wikiv7/index. ... t_in_color
https://www.flowcode.co.uk/wikiv7/index. ... Flowcharts
In my case I do not have/see the Print option and in the Global Options Application Tab I have fewer options to check.
What setting for FC7 do I miss? Or is it somewhere a bug?
FC7_print missing.jpg (68.74 KiB) Viewed 2971 times
FC7_Global Options_Application Tab.jpg (50.49 KiB) Viewed 2971 times
Re: FC7 - Global Options and Print missing or hidden
Hi Viki2000,
I think this has been covered before but the print has been hidden from the menu because the output was not very well suited for a printer. You can still press control + P to bring up the print dialogue if required.
A better way to print/document a project could be the File -> Save Image or File -> Create Project Report.
The Application tab does seem to have changed significantly from the image on the Wiki so I will see if we can get this fixed.
