E-Block EB006 and Flowcode
Fer_taca
Has thanked: 13 times
Been thanked: 10 times
Post by Fer_taca »
I am new using Flowcode, download the evaluation version 7, and acquired a series of e-blok to practice, for now only the EB006 (multi-programmer) has arrived, I am waiting for the rest: switches, LEDs, LCD, ....
Has done and simulates a very basic thing like reading and painting and activating an output, read an analog and see it on the LCD and now I would like to pass it to EB006 and I would like to know if there is a place where you can make some kind of document document , more or less clearly, the steps to pass what has been done to the indicated hardware.
He also knew that the dubbager can be performed and I really do not know how it is done or the steps to follow. so if someone has some kind of explanation of how to do it and / or get it, I would greatly appreciate it.
Thanks in advance.
F.
Re: E-Block EB006 and Flowcode
This should help to get you started.
https://www.matrixtsl.com/courses/itm/index.php
Fer_taca
Post by Fer_taca »
Thank you very much Mr. Benj for your response.
Really almost everything that appears in the link attached.
What I really miss is an example, even a very simple one, of the steps to be taken since the project was made and simulated, to pass this project to the EB006 board.
Also, on this plate it is indicated that it has a pre-recorded software to carry out a revision of the project in the form of In Circuit Debugging.
Is it necessary for some hardware or additional software?
Is there a document or procedure to study it?
On the other hand in the link appear some examples within the section "LABs"
To follow this course, is it necessary to be registered in some way?
Thanks in advance
Connect the EB006 to the PC via the USB cable, Ensure the board is powered (power jumper in the USB position), Ensure USB drivers are installed, Click the compile to chip button in Flowcode.
This video should help.
https://www.youtube.com/watch?v=kP4LW90biG4
We are in the process of making some videos to document this better, for now we have this in the wiki.
https://www.matrixtsl.com/wikiv7/index. ... Technology
And this on the blog.
https://www.matrixtsl.com/blog/ghost-technology/
Fer_taca
Post by Fer_taca »
Thanks for your kind response.
I need to know all the information that you have indicated
