RTC DS3231 missing white space error ( Arduino Mega 2560 rev3)
An area to discuss AVR and Arduino specific problems and examples
zadah
Has thanked: 3 times
Been thanked: 7 times
Post by zadah »
I get following compiler error on FC7 after trying DS3231 RTC module (Otherwise system works OK with i2c OLED display)
FC7 version: 7.2.1.4
C:\Users\Arska\Dropbox\FLOWCO~1>"C:\PROGRA~2\FLOWCO~2\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega2560 -Os -funsigned-char -o "C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.elf" "C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c" -lm
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:119:24: warning: missing whitespace after the macro name
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:120:24: warning: missing whitespace after the macro name
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:120:1: warning: "MX_I2C_CAL_I2C1" redefined
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:119:1: warning: this is the location of the previous definition
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:121:24: warning: missing whitespace after the macro name
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:121:1: warning: "MX_I2C_CAL_I2C1" redefined
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:120:1: warning: this is the location of the previous definition
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:136: error: expected declaration specifiers or '...' before 'FCD_0a3a1_RTC1__ReadTime'
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:136: error: expected declaration specifiers or '...' before '(' token
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:136: warning: data definition has no type or storage class
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:140: error: expected declaration specifiers or '...' before 'FCD_0a3a1_RTC1__ReadDate'
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:140: error: expected declaration specifiers or '...' before '(' token
C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:140: warning: data definition has no type or storage class
In file included from C:\Program Files (x86)\Flowcode 7\CAL\includes.c:413,
from C:\Users\Arska\Dropbox\FLOWCO~1\arduinotest.c:520:
C:\Program Files (x86)\Flowcode 7\CAL\/AVR\AVR_CAL_PWM.c:105:5: warning: #warning "PWM Channel Uses Resource Timer 0"
C:\Program Files (x86)\Flowcode 7\CAL\/AVR\AVR_CAL_PWM.c:472:3: warning: #warning "Period control register not available on target device, period will default to 255 + 1"
Has thanked: 481 times
Been thanked: 699 times
Re: RTC DS3231 missing white space error ( Arduino Mega 2560 rev3)
Could you try the updates from here....
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18760
If that does not fix the issue, please post your project file (*.fcfx)
zadah
Post by zadah »
After updates RTC is working ok, thanks.
I also noticed that DS3231 component from FC6 is working ok in FC7. (at least on arduino?)
viewtopic.php?f=58&t=14566
How usually FC6 components are compatible with FC7? Does it depend on compiler?
Yes, it would depend mainly on if there is any embedded C in the component
