Hi All
1. PIC16LF1902 and PIC16LF1903 Mcu's have a config Internal OSC 16Mhz configuration problem.
When it is set internal OSC and OSC frequency 16 Mhz configuration, MCU' is working very slowy.
2. PIC16LF1902 and PIC16LF1903 Mcu's have TMR Interrupt Problem:
Doesn't worked.
When I writing following to C codes in the program, has worked MCU's.
Could you please fix bugs.
Thank you.
PIC16LF1902 Configuration and TMR Interrupt Problem
- celebriums
- Has thanked: 71 times
- Been thanked: 33 times
- PIC16LF1902 (has working version).fcfx
- (31.68 KiB) Downloaded 261 times
- PIC16LF1902 (has not working version).fcfx
- (30.86 KiB) Downloaded 217 times
Re: PIC16LF1902 Configuration and TMR Interrupt Problem
Hi celebriums ,
The non working version won't run at the correct speed using internal oscillator because you are not using a Ccode block at the very start with
I can see a bug with fcdx file as when using Osccon helper there are no values to select.
OSCCON=0X78; Martin
- celebriums
