TMR Interrupt Problem
john_m
Post by john_m »
hello
found the same problem with the timer interrupt
the sample softpwm-1.fcfx runs in simulation on fc6 not on fc7
there is no timer interrupt
done a test on a ecio40p16 same problem
is this a bug or am i missing something in the set-up of fc7 ?
thanks
Re: TMR Interrupt Problem
Hi John,
Welcome to the forums.
The timer interrupt taking a long time to trigger with simulation only is a know bug.
It will trigger after a while. What I do for testing purposes is disable interrupt and just use a call macro.
Then when finished debugging just disable call macro and re-enable timer interrupt component.
It has been fixed in the next update that's due to be released.
