PIC32MZ2048EFM144 UART Interrupt (SOLVED)
An area to discuss 32-bit PIC specific problems and examples
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
Hi Ben,
Now there is a problem with UART interrupt.
When a byte is loaded into RX FIFO it does not cause interrupt.
I used the Configure setting, what Stefan Erni suggested.
(Boot ISA Selection=Boot code and Exception code is MIPS32)
I tried to debugging with different settings of SFR (priority level, INTCON) in the MPLABX, but I haven't got any result yet. :(
I tested the Timer Interrupt on this MCU and it works.
Do you have any idea to the solution?
Best Regards,
Lagoda
PIC32MZ_Timer_Interrupt_works.fcfx
(12.7 KiB) Downloaded 490 times
PIC32MZ_UART_Interrupt_Doesn't_work.fcfx
(12.49 KiB) Downloaded 501 times
Re: PIC32MZ2048EFM144 UART Interrupt
Hi Lagoda,
Please can you try this updated definition file and see how you get on.
Simply copy the file into your "Flowcode 7/FCD/PIC32" folder and restart Flowcode.
32MZ2048EFM144.fcdx
(78.8 KiB) Downloaded 547 times
If this works then I'll roll out the change to the rest of the family.
Lagoda
Post by Lagoda »
Hi Ben,
Works well with the test program. :)
I have created an UART bridge on the target panel between the GSM module and an RS232 interface with UART RX interrupt.
Unfortunately, it does not work in this program.
Maybe I did something wrong.
I'll check it out.
Thanks for the quick fix.
I'll let you know if I have a result.
Best Regards,
Lagoda
Lagoda
Post by Lagoda »
:D Joy and happiness!!! :D
The improved version that you have created works perfectly.
The UART bridge now works in my circuitboard, but I do not know what it was. :o
Thanks again for your help.
Lagoda
Re: PIC32MZ2048EFM144 UART Interrupt (SOLVED)
Brilliant thanks for letting us know and glad it's working :D
This problem was effecting all of the UART RX interrupts on PIC32MZ devices.
I've just managed to roll out and squeeze this fix into the 7.3 release which hopefully goes live tomorrow.
