Hello everyone. I have one small problem. Cannot compile fex file, and programe write this error:
C:\Users\D395~1\DOCUME~1\first>"E:\163C~1\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega8 -Os -funsigned-char -o "C:\Users\D395~1\DOCUME~1\first\Flowcode1.elf" "C:\Users\D395~1\DOCUME~1\first\Flowcode1.c" -lm
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c:43:49: error: E:\????????\Flowcode7\CAL\internals.c: Invalid argument
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c:77:48: error: E:\????????\Flowcode7\CAL\includes.c: Invalid argument
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c: In function 'FCD_03d91_led_base1__TurnOn':
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c:92: error: 'B' undeclared (first use in this function)
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c:92: error: (Each undeclared identifier is reported only once
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c:92: error: for each function it appears in.)
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c: In function 'FCD_03d91_led_base1__TurnOff':
C:\Users\D395~1\DOCUME~1\first\Flowcode1.c:109: error: 'B' undeclared (first use in this function)
E:\програмы\Flowcode7\compilers\avr\batchfiles\avra.bat reported error code 1
FINISHED
Can you help me with this problem. I will be appreciative
Compile error
Re: Compile error
Hi igore14105,
Welcome to Matrix forums.
I have moved your post to a more suitable section.
As you have not attached your flowchart, at best we can only guess what the issue is.
My guess is you have not assigned a LED component to a suitable port E.G A0
