Adafruit 4x20 LCD
keithh534
Has thanked: 15 times
Been thanked: 12 times
Adafruit 4x20 LCD
Post by keithh534 »
It seems the cursor method of the LCD_4x20 (Adafruit, OLED) component doesn't work. Whenever the simulation calls the method, it hangs.
Am I doing something wrong?
If not, when can I expect this bug to be fixed?
Has thanked: 481 times
Been thanked: 699 times
Re: Adafruit 4x20 LCD
Seems to work OK for me,
Did you first call Start()?
Could you post a project file, *.fcfx?
keithh534
Post by keithh534 »
Yes, in the 'Startup' macro as shown below.
The 'Main' calls 'Startup' which calls 'Pgm' when the 'PGM' key is pressed. It hangs at the first instance of the cursor method.
btw: This program works without issue with the generic 4x20 LCD component.
keithh534
Post by keithh534 »
Sample program attached demonstrates issue
LCD Test.fcfx
(13.98 KiB) Downloaded 294 times
Thanks, perfect!
Probably won't get chance to look at this until return to office 2nd Jan.
Please use the attached updated component, drop into your Flowcode /components directory.
(The sim Cursor function was waiting for the ready pin - this has now been removed)
Leigh
LCDAdafruitOLED4x20.fcpx
(25.34 KiB) Downloaded 261 times
keithh534
Post by keithh534 »
Much better!
Thank you!!
