16f18313 not support?
seokgi
Has thanked: 18 times
Been thanked: 16 times
Post by seokgi »
that is question.
(7.36 KiB) Downloaded 2524 times
Re: 16f18313 not support?
Thanks for letting us know. The attached files should solve the problem for you. Simply copy the files into your "Flowcode 7/FCD/PIC" folder and restart Flowcode.
16F18313.fcdx
(20.34 KiB) Downloaded 294 times
16LF18313.fcdx
(20.34 KiB) Downloaded 299 times
Let us know how you get on.
dannyvanneijenhoff
Has thanked: 17 times
Been thanked: 10 times
Post by dannyvanneijenhoff »
For this pic, i can not find the INTERNAL CLOCK Source Types . Also for Pic16F18323
Last edited by dannyvanneijenhoff on Thu Mar 22, 2018 7:06 pm, edited 1 time in total.
The top setting is "External Oscillator Mode", the next setting down is the "Software Oscillator Mode" and has a HFINTOSC setting available.
dannyvanneijenhoff
New micro, more functions :oops:
dannyvanneijenhoff
I have problems with RA3: (for Pic16F18323)
R-pull Up is working (on and off)
MCLR is now off (after set low voltage proramming OFF)
Input works also
But no OUTPUT on RA3
In the PDF of the micro stands:
RA3/MCLR/VPP RA3 TTL/ST CMOS General purpose I/O.
MCLR TTL/ST — Master Clear with internal pull-up.
VPP HV — Programming voltage.
The MCLR pin on PICs is not available as an output pin due to silicone limitations it's input only I'm afraid.
dannyvanneijenhoff
Thanks,
There was different information :-(
TABLE 1-2: PIC16(L)F18313 PINOUT DESCRIPTION
RA3 /MCLR/VPP TTL/ST CMOS General purpose I/O.
And on other places:
• Up to 12 I/O Pins: (but 1 = input)
The MCLR pin provides three specific device functions:
• Device Reset (when MCLRE = 1)
• Digital input pin (when MCLRE = 0)
• Device Programming and Debugging
