Component gLCD_SSD1306_i2c1
gdt
Has thanked: 25 times
Been thanked: 36 times
Post by gdt »
I'm playing with a 128x32 OLED with SSD1306 driver but in simulation it looks like I can't draw in Y more than 29 pixel.
I would expect to draw a rectangle from 0,0 to 127,31 but in Y I can't see anything above 29. It seems shifted in Y by 2 pixels because the top line is actually at 0,2.
Could you please take a look?
Giuseppe
Test_OLED_128x32.fcfx
(8.11 KiB) Downloaded 268 times
gdt
Re: Component gLCD_SSD1306_i2c1
Post by gdt »
I've just noticed that if I set the display Property -> Simulation Mode -> Display Method to Point Cloud instead than Bitmap it works fine!
Then not an issue.
Giuseppe
Hi Giuseppe,
Thanks for letting us know. It appears to be an issue on all graphical LCDs. Maybe the bitmap drawing routine has changed for 7.3. I'll see if I can work out why this has happened.
Anyway this updated GLCD_Base component will fix the simulation problem for the bitmap mode, simply copy the file into your "Flowcode 7/Components" folder and restart Flowcode.
Base_GLCD.fcpx
(9.16 KiB) Downloaded 274 times
Let us know how you get on.
gdt
Post by gdt »
Hello Ben,
thanks always for your answers! But, if I remember correctly, it was the same before I upgraded to FC 7.3.
Anyway it's fine now, thank you!
Giuseppe
