vinculum 1 usb host controller
A forum where Flowcode v7 user created components can be shared, discussed and reviewed.
RLOPES780
Been thanked: 3 times
Post by RLOPES780 »
In the flowcode v6 user component topic our friend Jordy had started building the component Vinculum1.fcpx. This was in the year 2014 and it seems that stopped with the project. I found it very interesting for the possibility of using pen drive and ease of use as datalogger.Porem I tried using it with a dspic33ep and I could not.It would be the end of this component for use with the families of microcontrollers.If it is possible to use how can I configure it? Or using the SPI or UART protocol, Here's an example of how to create a directory with the MKD command for example.
Thankful;
Ricardo
Vinculum1.fcpx
(6 KiB) Downloaded 421 times
