Help with LCD connection
kostalex
Post by kostalex »
Hello I would like your help.
I have an LCD screen which uses RA8835. I was going through the flowcode examples and I see that the example that uses KS0108 LCD has cs1 and cs2 pins. My LCD (RA8835) only has a CS pin. Do you know what I have to change in the aformentioned example in flowcode in order to make it work?
Re: Help with LCD connection
I don't think we currently support this display driver IC. I'll add it to the list to try and investigate.
kostalex
Post by kostalex »
Thanks. we will looking forward your reply cause we really need it for our project
The display would be a new addition so won't be included with Flowcode 6. Would Flowcode 7 be an option for you or would you like to see how GLCD components are made so you can have a go yourself.
This should show you how the components are created and applies to v6 as well as v7.
viewtopic.php?f=66&t=19116
kostalex
Post by kostalex »
thanks for the link but I don't think i will be able to make it work. I want to use a glcd 5.7" but the only one i found is the ra8835 ,,, http://www.buydisplay.com/
ERM320240-2_Series_Datasheet.pdf
(343.56 KiB) Downloaded 278 times
I think to buy the flowcode 7 when included the component GLCD RA8835
