Trying to add the spi LCD to an Arduino Uno within flowcode. On compilation I get the following "FCP_SET" requires 5 arguments, but only 2 given errors. I have checked for unconnected pins but can't identify any.
Target folder: C:\Users\asr\DOCUME~1\Arduino\flowcode
Source name: C:\Users\asr\Documents\Arduino\flowcode\F3.fcfx
Title:
Description:
Device: AVR.ATMEGA.ATMEGA328P
Generated by: Flowcode v7.3.0.5
Date: Sunday, January 07, 2018 21:51:49
Users: 1
Registered to: reedas
Licence key: UM6C2D
NOT FOR COMMERCIAL USE
http://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat atmega328p "C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.elf" "C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c" "C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.lst"
C:\Users\asr\DOCUME~1\Arduino\flowcode>"C:\PROGRA~2\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.elf" "C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c" -lm -Wl,-gc-sections
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:530:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c: In function 'FCD_04071_LCD__RawSend':
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:530: error: 'FCP_SET' undeclared (first use in this function)
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:530: error: (Each undeclared identifier is reported only once
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:530: error: for each function it appears in.)
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:531:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:532:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:533:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:534:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:535:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:545:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:547:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:549:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:551:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:581:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:595:21: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:599:21: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:605:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:606:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:607:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:608:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:609:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:612:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:614:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:616:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:618:40: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:623:23: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:631:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:635:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:681:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c: In function 'FCD_04071_LCD__Start':
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:681: error: 'FCP_SET' undeclared (first use in this function)
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:682:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:683:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:684:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:685:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\asr\DOCUME~1\Arduino\flowcode\F3.c:686:22: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat reported error code 1
FINISHED
TIA
Andrew
Arduino LCD compilation errors
Re: Arduino LCD compilation errors
Hi Andrew,
No one will be able to help unless you attach your flowchart.
This is the code, arduino and 16x2 i2c lcd, initialise, clear screen, move cursor, print("Hello World!"). Thanks
Andrew
Andrew
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Hi Andrew,
Thanks for the example.
Please update your LCD component in your Flowcode installation /components directory with the one attached below.
Leigh
Leigh
- lcd_I2C.fcpx
- (26.23 KiB) Downloaded 350 times
