Calculation Symbol
JDR04
Has thanked: 111 times
Been thanked: 13 times
Calculation Symbol
Post by JDR04 »
When using the CALCULATION SYMBOL I would like to know what the line ;
Duty = Duty * 53/100 means and its influence please. I have attached a screen grab as well. Thanks folks.....John
Calculation Symbol 2.jpg (64.94 KiB) Viewed 5660 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Calculation Symbol
Post by kersing »
This looks like a question that can use some context.
In you diagram the line simply means the variable duty is multiplied by 53 and then divided by 100. (Which will not yield the result you expect because the multiplication overflows the byte [0-255 value range] variable (5 * 53 = 265 which results in duty becoming 10)
What duty does in your code we can't guess because we there is no flowchart...
― C.S. Lewis
JDR04
Post by JDR04 »
Thanks for replying.Here is the flow chart in question.
Thanks for your help////John
16F690 PWM EXP.fcf
(13.53 KiB) Downloaded 298 times
JDR04
Re: Calculation Symbol-Is this Correct?
Post by JDR04 »
OK.could somebody tell me if I'm right or wrong please.
When using the calculation ,Duty=5*53/100 should be Duty=5*51/100
So my assumption is that whatever your Duty number is it should not be multiplied by anything that results in a number bigger than 255?
Hi John,
Since a byte is maximum value is 255, then:
255 + 1 = 0
Another example:
255+ 5 = 4
etc.
Also
0 - 1  = 255
That's why the result of a byte can't be greater than 255.
If it is, then unexpected results will be seen.
So Jac is correct but only if /100 was not used after.
You can have intermittent value within a calculation higher than 255.
It could be as high as 32767 as singed integers are used as temporary variables.
So long as final result is not greater than 255.
For your example:
Duty=5*53/100
Is allowed as the final result will be 2:
5 * 53 = 265
265 / 100 = 2.65
= 2
Note:
Numbers are not rounded up, so 2.65 will round down to 2
