Encoder rotary for the simulation
A forum where Flowcode v7 user created components can be shared, discussed and reviewed.
jojo31
Been thanked: 4 times
Post by jojo31 »
The Encoder rotary component exist but not for the simulation like switch, slider, ...
Is it possible to have this new component because I am creating an other component (expander + 4 encoders)
Thank you very much
Best regards
Re: Encoder rotary for the simulation
The Encoder Rotary component under inputs should have simulation and also simulate the pin states. What parts of the simulation are you currently missing?
jojo31
Post by jojo31 »
I need this component without pins connection because it is integrated in my new component that I want to simulate.
The new component is an MCP23017 connected to several rotary encoder.
Best regards
Have a go with this and see if it does what you require.
Simply add to your v7 installation by copying the file below into your "Flowcode 7/components" folder.
SimQuadEncoder.fcpx
(3.1 KiB) Downloaded 440 times
The two pin states can be collated from the ReadCounter macro.
Pin1 = Counter & 0x01
Pin2 = (Counter & 0x02) >> 1
Also here is the source project if you want to have a play with it.
SimQuadEnc.fcfx
(21.16 KiB) Downloaded 467 times
Let us know how you get on.
jojo31
Post by jojo31 »
I included one "SimQuadEnc" in "MCP23017_Encoder" component witch has INTA & INTB pins.
MCP23017_Encoder.fcfx
(18.04 KiB) Downloaded 464 times
In the macro "CheckChangeSim" I read the counter of the "SimQuadEnc" and I check any change to set INTA.
But it's not a good solution, it's better if I can generate an interruption from the state of pin1 & pin2.
Click -> INT (SimQuadEnc) -> INTA (MPC23017_Encoder)
How to generate an interruption in the sub component "SimQuadEnc" that I can treat in the MCP23017_Encoder component ?
Is it possible to read a global variable set in "SimQuadEnc" linked with one property added in the "component properties" ?
Thank you for your help.
Best regards
