The window does not clos
Osta
Been thanked: 13 times
Post by Osta »
Opened the window (information about the program) and now it closes only through the task manager.
I had to stop the Flowcode process in the task manager ........
Re: The window does not clos
There should be a close button at the bottom right hand side of the window. What DPI setting are you using and we will investigate?
Osta
Post by Osta »
Hello Benj I have 1000DPI
I know that there is a button. This happened after updating 7.3.0.6
Now this button is not available ......
Hi Osta,
In Windows 10 in the Display Options you can have a Scale of 100% to 175%.
In previous versions of Windows this was referred to as the DPI setting.
Can you say which setting you have on your current version of Windows so we can try and reproduce the problem.
Osta
Post by Osta »
Hello Benj!
Yes, I have 150%.
Resolution 3840 x 2160
thank you Osta!
Hi Osta,
Thanks for letting us know. I've just tried the 150% on a 1080p HD monitor and the close button is available.
I'll try the same tonight on my Ultra HD monitor and see if I can replicate the issue there.
