Why this delay ?
ylanchec
Has thanked: 2 times
Been thanked: 2 times
Why this delay ?
Post by ylanchec »
In I2C lib, at the end of the STOP there is a big delay, why ?
(92.81 KiB) Downloaded 1438 times
Thank you
Yannick
Has thanked: 481 times
Been thanked: 699 times
Re: Why this delay ?
Some devices seem to need it.
But the delay can be enabled or disabled in the component ..
ylanchec
Post by ylanchec »
Hi LeighM,
Sorry, I had not seen this possibility !
Thank you for your help.
Yannick
Some early PIC and AVR devices can lock up if the delay is not present, i.e. if you try and start before the stop has finished being output by the peripheral.
On most newer devices you can remove the stop delay without any issues via the property Leigh mentioned.
