i have a short question. Is it possible to have more then 8 Servos for example under ds30F6011A control.
In simulation I can activate two servo controler running a setup with more then 8 servos (for example 12 Servos). This works.....
You can select/define controller 1 and 2.
Trying to compile you will get a error mesage and you don`t get the hex file.
I belive this has to do with the timer and timer interups in the servo controller component!!!! Right??
Is there a chance to modify the servo controller component??
Attached a FC file with the call for two servo controller.
BR
Dirk
