Issue with config setting
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
Not sure this is a bug per se, but I get a compiler warning when compiling a program for the PIC12F615:
33: __config("__PROG_CONFIG", "pic", 0x1, 0x3D94);
^ (1386) unable to determine the semantics of the configuration setting "BOREN" for register "CONFIG" (warning)
Since this is something that is set in the Configure dialog in Project Options, I thought I'd flag it here. This happens with BOREN disabled; when I enable it in the Configure screen, the warning disappears.
Jan Didden
Linear Audio
Re: Issue with config setting
Hi Jan,
Thanks for letting us know. There is a don't care bit in the datasheet but obviously the compiler does care about this bit.
I've fixed the definition files so that the problem should now be resolved. Please note that you will have to go back into the configuration options and change the brown out setting to one of the settings in the list.
12F615.fcdx
(11.97 KiB) Downloaded 190 times
