I'm trying to use this small 0.66" (64x48 pixel) display, however it's ok in simulation but in the real chip it looks like it's doubling the Y printing coordinate and also it's not possible to print anything when Y<7.
See how it looks in the simulation and in the real chip.
Could you please check the component?
Giuseppe
GLCD (SSD1306) I2C component display.
- Test_OLED(SSD1306_I2C)_64x48_PIC18LF26K80_v1.fcfx
- (11.9 KiB) Downloaded 205 times
- Simulation_OLED(SSD1306_I2C)_64x48.jpg (19.31 KiB) Viewed 3027 times
- Test_OLED(SSD1306_I2C)_64x48.jpg (64.3 KiB) Viewed 3027 times
Re: GLCD (SSD1306) I2C component display.
just an update: if I set Property -> Dimensions -> Interlaced -> YES then the output looks better but still some part of the display (lower part) is not shown.
This should be an easy fix...please!!!
Giuseppe
Giuseppe
- IMG_0803.JPG (28.98 KiB) Viewed 3015 times
just an update to say that I've modified the component (thanks to Matrix Team to share!) and now the display is working as expected.
Giuseppe
Giuseppe
- Test_OLED(SSD1306_I2C)_64x48.JPG (61.33 KiB) Viewed 2980 times
- gLCD_SSD1306_i2c.fcpx
- (11.38 KiB) Downloaded 221 times
