OLED Display (SH1106).
gdt
Has thanked: 25 times
Been thanked: 36 times
Post by gdt »
I don't know if this is a bug but I bought this display driven by SH1106 controller and unfortunately it has I2C Addresses bits at 0x78 and 0x7A (like SSD1306), differently than the component in FC7 gLCD_SH1106_I2C1 which uses 0x3C and 0x3D.
Would it be possible to select these addresses?
Also this is a 4 pin components and the Reset pin is missing.
Giuseppe
Re: OLED Display (SH1106).
Hi Giuseppe,
I believe the addresses we use include the bit shift for the least significant R/W bit. It just makes the code slightly more efficient as you'r not doing the bit shift at run time.
0x3C = 0b00111100
0x3D = 0b00111101
0x78 = 0b01111000
0x7A = 0b01111010
Is the reset pin missing from the display or component? If it's missing from the component then you can simply drive the reset signal from VCC or from a free output pin, drive the pin high and then wait a few hundred milliseconds before communicating with the display.
If it's missing from the display then it's probably just been hard wired to VCC for you. Just attach the component pin to an unused I/O pin. Maybe we can make this optional if you have no free pins on your device.
gdt
Post by gdt »
Hello Benj,
thanks for replay!
First of all the display is sold having an SSH1106 driver but I believe it's a typo since I found only the attached SH1106 datasheet.
Also this driver is for a 132x64 pixels (the FC component is 128x64 and cannot be changed).
The RST is missing in the display. As you can see it has 4 pins: GND, VCC, SCL and SDA.
If I leave the Reset to "Unconnected" then FC doesn't compile giving errors:
Build date: Sep 13 2017
Part Support Version: 1.44
Copyright (C) 2017 Microchip Technology Inc.
Test_OLED(SSH1106_I2C)_128x64_PIC18LF26K80_v1.c:
1872: FCP_SET(FCP_NULL, 0);
^ (171) wrong number of preprocessor macro arguments for "FCP_SET" (2 instead of 5) (warning)
1876: FCP_SET(FCP_NULL, 1);
Test_OLED(SSH1106_I2C)_128x64_PIC18LF26K80_v1.c: FCD_006e1_gLCD_SH1106_I2C1__Initialise()
1872: FCP_SET_FCP_NULL(0, , , );
^ (361) function declared implicit int (warning)
^ (195) expression syntax
(194) ")" expected ^
(195) expression syntax ^
1876: FCP_SET_FCP_NULL(1, , , );
(908) exit status = 1
C:\Program Files (x86)\Microchip\xc8\v1.44\bin\xc8.exe reported error code 1
FINISHED
Then I have to attach the Reset to a pin (RC2) to get an hex file.
Here is a flowchart to test it. The same chart using an SSD1306 I2C 128x32 works fine.
Please note that if I download to chip the hex file even the LED doesn't flash (Test_OLED(SSH1106_I2C)_128x64_PIC18LF26K80_v1).
If I delete all macros related to the display and I leave the LED (Test_LED_PIC18LF26K80_v1) it blinks as expected.
Any help is very appreciated.
Giuseppe
SH1106.pdf
(709.42 KiB) Downloaded 311 times
Test_OLED(SSH1106_I2C)_128x64_PIC18LF26K80_v1.fcfx
(14.1 KiB) Downloaded 338 times
Test_LED_PIC18LF26K80_v1.fcfx
(9.44 KiB) Downloaded 274 times
gdt
Post by gdt »
All,
just to say that after some troubleshooting I realized that my display was faulty! :x
I used a new one and everything was fine.
However if you don't have a spare pin in the PIC to attach to Reset (this display has 4 pins: GND, VCC, SCL, SDA) find attached a component without Reset pin.
Giuseppe
(79.57 KiB) Downloaded 1533 times
gLCD_SH1106_I2C.fcpx
(11.14 KiB) Downloaded 291 times
