ILI9341 slow work
maharadga
Has thanked: 17 times
Been thanked: 12 times
ILI9341 slow work
Post by maharadga »
I try module TJCTM24024-SPI with ILI9341 controller. I see that display work very-very slow. My frequency is 32MHz.
Is this normal or not?
I attach simple programm.
PIC18F2520_ILI9341.fcfx
(12.03 KiB) Downloaded 194 times
gdt
Has thanked: 25 times
Been thanked: 36 times
Re: ILI9341 slow work
Post by gdt »
I see in the configuration you are using HS-PLL enabled.
I don't have the same PIC but I used 18LF26K80 time ago to write in similar display and to enable PLL I had to use a C block at beginning of the flowchart like:
OSCCON = 0b01110000;
OSCTUNE = 0b01000000;
Check in the datasheet the right values and registers for your PIC, maybe this is the problem.
Giuseppe
