Store Flash Data (Eeprom?) STM32F051
sblsolutions
Hello everyone,
I'm working quite a few years with flowcode for PIC but now I want to go for the STM32 controllers.
I've made some hardware for a project and used the STM32F051c8, because this one is in Flowcode.
The datasheet says :
The non-volatile memory is divided into two arrays:
–16 to 64 Kbytes of embedded Flash memory for programs and data
–Option bytes
But how can you read and write data to this flash data range?
It's not possible with the Eeprom symbol.
Kind regards,
Rene de Jong
–Option bytes
Kind regards,
Rene de Jong
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Store Flash Data (Eeprom?) STM32F051
We don't currently have any support for in program writing of Flash memory on STM32 devices.
We'll add it to our list for possible future additions.
- LeighM
I've created some macros that might work, sorry I've not had chance to test them.
Just ensure that the Address is not within your program space!
Hope it helps, let me know how it goes.
ps. the FlashByte won't work on F0, but should on F4
- ReadHalfWord.fcm
- (491 Bytes) Downloaded 639 times
- ReadWord.fcm
- (487 Bytes) Downloaded 614 times
- FlashWord.fcm
- (607 Bytes) Downloaded 643 times
- FlashHalfWord.fcm
- (615 Bytes) Downloaded 652 times
- FlashByte.fcm
- (606 Bytes) Downloaded 632 times
I did try this a long time ago. I recently took another look and couldn't get it to work. Might (probably) be my fault.
Could you take a look at this again when you have the time? A little flash byte read byte program would be really helpful.
Thanks!
cahd
Thanks!
cahd
- LeighM
Hi Chad,
Depends on how you want to use it.
Would a lookup table suffice?
The Flash has it's limitations as it needs to be block erased.
So byte write/read isn't going to be efficient.
Leigh
Leigh
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Hello!
Excellent work!
If the page block is not empty, you cannot write data.
How do I delete the data stored on the page?
Excellent work!
I tested these macros
Reading is not a problem and it works
I wrote and tested but it was written only once, it is not written a second time
stm32-flash eeprom
- FLASH-ERASE.fcm
- (553 Bytes) Downloaded 450 times
- FlashHalfWord.fcm
- (615 Bytes) Downloaded 421 times
