Hi All,
I am having difficulty with printing a space when the * button is pressed. I have seen other members ask this question and I have had a look at other peoples keypad programs. I have tried using 32, as the keypad number, which in theory should be printed as the ASCII equivalent which is a space.
My program uses a number which is multiplied by 10 and then added to the key pressed, so it can be displayed one after the other. I have got very close with this problem, as I have now managed to print a number one after the previous by pressing *, but it stays at 32 instead of going to the space icon.
E.g I want to input numbers like 0123 and then when * is pressed the next number will go after with a space so, if I pressed 6 after it would be 0123 6 on the LCD
I have attached my program, I think the problem may lie with the program afterwards which then converts my number variable into a string. If anyone knows how to print a space bar using *, then I would appreciate your help,
Kind Regards,
Jaco
Printing a space bar using a keypad
Re: Printing a space bar using a keypad
Hi everyone,
Just thought I would let you know I have now solved this issue!
By changing my program extensively to not using strings and instead using a variable for the cursor x which is incremented. For the space to show, I used print string and then just " ", should have thought of this before!
I've attached the program below, as reference for anyone in the future who has the same issue
All the best,
Jacob
All the best,
Jacob
- Ex 9 prog 4 new version fcfx.fcfx
- (18.83 KiB) Downloaded 223 times
