I need help for a pH and Humidity project.
Ficher
Post by Ficher »
Hello everyone, I have a project to do in class, i need to use flowcode and PIC16F877A, and I chose pH sensor (SEN0161) and Humidity sensor (YL-69), I created the program for both and it works in simulation but he doesn't work with the sensors. I searched how i can use the sensors but everything is on Arduino. If anyone can help me, thank you very much.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: I need help for a pH and Humidity project.
Post by kersing »
Perhaps you could post your code so we can give you pointers to what might be wrong? Given the amount of information you have given us at the moment we need a crystal ball...
― C.S. Lewis
Ficher
Post by Ficher »
No problem here's the code for the pH :
Capture 1
Capture 2
And the Humidity :
Capture 3
Capture 4
I just need help for the use of the sensors normaly the program works.
(207.15 KiB) Downloaded 3341 times
(196.42 KiB) Downloaded 3341 times
(183.46 KiB) Downloaded 3341 times
Ficher
Post by Ficher »
Capture 4
(195.63 KiB) Downloaded 3340 times
kersing
Post by kersing »
Please attach a flowcode file, screendumps only show us only part of what we normally check. (For instance clock settings, component connections etc)
― C.S. Lewis
Ficher
Post by Ficher »
The two flowcodes codes 1 is for pH and 3 for Humidity.
Flowcode3.fcf
(15 KiB) Downloaded 318 times
Flowcode1.fcf
(11.5 KiB) Downloaded 275 times
johnsondav
Has thanked: 86 times
Been thanked: 186 times
Post by johnsondav »
Hi Ficher
I would suggest you change the 'Clear' LCD with the following to get a smother display:
Not sure if the flikering display is your problem but this would help. Also, your math is a constant ( *100 / 5) = 20
just multuply your voltage by 20 and it should give your the same result - faster, if the 20 is stored as a variable. Microchip compiler always converts any number system to a hex value before it is compiled, this is how they acheive the 20% speed increase.
Hope this helps.
Dave
Ficher
Post by Ficher »
Thanks for your help I go change the program to make it better.
