Numerous errors when compiling to HEX code
Hi, I have just stared using FC7. I wrote a small test flowcode, but when I try and compile, I get a heap of errors. I'm sure its just a setup issue. Is there a topic that discusses the setup of FC7 and compiler setup? I've attached the small FC, but not sure how to attach the error report as I wont let me copy it.
- Test_FC7.fcfx
- (8.32 KiB) Downloaded 259 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Numerous errors when compiling to HEX code
There is nothing wrong with your project file.
Where are you saving it on your PC?
Could the problems be due to admin rights on the directory?
Why can't you read/copy "Test_FC7.msg.txt"?
My apologies,
I've attached the .msg file. If I remove the LCD component then it compiles?
Thanks.
Thanks.
- Test_FC7.msg.txt
- (7.07 KiB) Downloaded 219 times
- LeighM
Could you try downloading and installing the patch update zip from here ...
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=19743
Thanks very much, that seems to have sorted the problem!!
