CAN Support,
An area to discuss 32-bit PIC specific problems and examples
QMESAR
Has thanked: 384 times
Been thanked: 614 times
CAN Support,
Post by QMESAR »
Hello Team.
Is there any news regarding the CAN internal module support and USB ,
When should we be expecting support in FC8 or 9 :D :D
Looking forward to hear some sort of projection, I know we were promised USB support soon just after the initial release of PIC32 support :D
Re: CAN Support,
Hello Peter,
USB should be in for PIC32 in 7.3.
It's not as neat as the 8-bit and 16-bit devices but it should work if you follow the instructions.
PIC32 USB Instructions.doc
(171 KiB) Downloaded 548 times
I'll get CAN on the list to investigate for v8.
QMESAR
Re: CAN Support,
Post by QMESAR »
Hi Ben.
Thank you very much .
I will give it ago .
Much appreciated and this would be great if it would be possible to have CAN in V8 :D :D
Have good one
r_teixeir
Has thanked: 24 times
Been thanked: 5 times
Re: CAN Support,
Post by r_teixeir »
Hi Team, in relation to the question of QMesar about the CAN Controllers for flowcode V8 or V9. There are different CAN controllers on the market that would want to simulate and program using flowcode as described below:
ATA6563
MCP2517FD
ADM3053
STN1110 Multiprotocol OBD
ATA6570
How is this development going and how easy it is to integrate these controllers with in V8, facing this different configurations and setups.
Thank you much
Rod
Docara
Has thanked: 28 times
Been thanked: 61 times
Re: CAN Support,
Post by Docara »
Why doesn't FC just allow us to use the internal CAN interface on a given uC sort out an interrupt for received addresses which have been setup up and have done with it? The actual physical connection can be utilised with interface chips.
Going out and trying to find CAN chips then write specific code for them seems daft.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: CAN Support,
Post by kersing »
Docara wrote:Why doesn't FC just allow us to use the internal CAN interface on a given uC
It does. For certain uCs. I think there are simply too many different controllers with CAN for Flowcode to support them all.
― C.S. Lewis
Docara
Re: CAN Support,
Post by Docara »
Hi Kersing,
Um are you sure??? I'm looking through my FC7 and I can't see any 'yellow crosses' against any of my CAN components but the only options I can see is for a MCP2515 component which is a SPI to CAN chip.
Or have the last three hairs I have left just turned blonde LOL?
Matt
kersing
Re: CAN Support,
Post by kersing »
Yes, l’m sure. I’ve used the component. I guess you are only looking at 8 bit devices? Some dspic33 devices are supported.
― C.S. Lewis
r_teixeir
Re: CAN Support,
Post by r_teixeir »
Hi Docara, i wanted to say transceiver, instead of Controller, my mistake. And you re right about the limitation of resources for different mcu while using its internal CAN interface.
Rod
